Documentation for Users  2.0.4
Perception Toolbox for Virtual Reality (PTVR) Manual
RGBColor Class Reference
+ Inheritance diagram for RGBColor:
Public Member Functions
def __init__ (self, r=0.0, g=0.0, b=0.0, a=1.0)
def get_color (self)
def set_color (self, r, g, b, a=1.0)
def to_json (self)
def __str__ (self)
Data Fields
 r
 g
 b
 a
 additionnal alpha layer More...
 type
Properties
 color = property(get_color, set_color)
Detailed Description
RGBColor specifies color as Red, Green and Blue values as floats in the range [0.0,1.0] each.
The Alpha value is a float in the range [0.0,1.0]. Alpha denotes transparency (0 is transparent and 1 is opaque).
Definition at line 13 of file Color.py.
The documentation for this class was generated from the following file:
